Hottech
 - Jun 22, 2019
- Threads
 - 6
 - 8
I was changing the  oil and filter  on my 38" simplicity  with an 18hp Intek single cylinder.   It had a brass  fitting  that attached  to an aluminum  block that  screwed  into  the cast iron  casing.   Needless  to say what kind of  engineering  process  designed  this.  There was also a rubber  o ring in the apparatus.  I loosened  the fitting  to  drain the oil  but it would not  seat when I  tightened it up  to  refill  the oil.   All my new  oil drained out making  a big  mess  plus the waste & cost of the oil.  Removed the complete  drain system  and replaced  with a $5.00 drain plug with  solved the problem.   Also why did the place the oil filter in the side of the frame so that only a small filter would  fit?  I took my grinder and cut the frame so a standard filter would  screw  in.  I thought  Simplicity  was better  engineered.
