I have a Craftsman DGS 6500 riding mower. I was mowing along just fine when it suddenly stopped. It clicks when I turn the key but won't start. It won't even turn the engine. I did a quick test bypassing the starter solenoid by touching the 2 posts on the starter solenoid and it turned the engine so I know the starter is good. The starter itself is fairly new. I replaced it about 2 months ago.
So, I replaced the starter solenoid today and still, it just clicks and won't turn the motor. I went ahead and also replaced the ignition switch. The same result. Can a bad PTO switch cause the mower not to start? That's the only thing I haven't replaced. I really don't want to take this to a repair shop. It seems like something I can easily fix. I just don't know what else I can try.
Your input is greatly appreciated.
