Having a problem disengaging tranny to push mower, when the little coat hanger type rod ( draw bar ) is in the engaged position the mower works fine , when I pull it out I cant push it , wouldn't disengage the tranny ,yes I have the emergency brake off. I looked under the mower couldn't see anything out of whack. I was thinking the brake was locked up but works fine, at least I'm able to stop. Could it be internal or something needs adjusting on the outside of the tranny in the linkage or adjustment somewhere ? Thank you in advance.
