I have a Craftsman Pro Series 8200 that the electronic PTO was cutting off when mowing the yard. I did a lot of research and replaced the PTO switch, Electronic PTO clutch, initially and still had the same issue. The mower at times seemed to not want to start  ( already have new battery) and so I replaced the ignition switch.  It started up normally but still had the issue with PTO switch engaging but cutting off.
I checked voltage of battery ... with motor off 13 volts.. with engine running on high idle 15 volts. So after more research I replaced the voltage regulator and took a chance to replaced the interlok since it was pretty cheap. It seemed to fix the issue.. it ran and PTO stayed engaged. That lasted about 4 times around the large back yard... and it everything seemed to be working fine. Then all of a sudden it started to cut off.. and on. What was really weird as was pissed and stomped on the forward pedal and the PTO would engage but cut off... each time I hit the pedal hard, PTO would engage and then cut off.
Anyone have experience with some weird issue like this? Already replaced PTO switch, Electronic PTO clutch, Ignition key switch, Interlok switch and the voltage regultor.
So frustrated with this thing. otherwise engine runs really good.
thanks
Jim
thanks
Jim
