Toro 06 LX460 - Bolt / Spacer Falling Out.
Doug.C
So as the title indicates, I have a problem with my Toro. The Bolt and Spacer are falling out now this year as the drive belt is engaged. My guess is the belt is loosening the bolt/spacer when I am engaging the double idler pulleys. The Nut/Thread appear to be built into the frame, unless I need to take the shell off to replace this part. The bolt will not tighten up 100% either. I'd guess it gets to about 40% torgue and then spins free again when tightening. Any advive/thoughts greatly appreciated!
IF it is the variable speed double pulley. Otherwise give us more on which screw and washer is coming loose.
Doug.C
Maybe all I need to do is take the fender off. Just don't want to mess with the tower if at all possible.
Replace the flange lock nut with a new one as nylon part is probably badly worn and no longer holding.
