Blacktrain11
- Jun 10, 2016
- 28
Briggs Model #33R877 Type #0008 G1 Code #180411ZD Engine seems to have high compression. Intake valve set a .003 Exhaust valve set at .005 engine will start to turn over then stops like there is too much compression, turn engine by hand a little bit more and it will sometimes start. Take the plug out and it turns over ok. New battery and new starter. flywheel key is ok. Any help is greatly appreciated. Thanks!
