whateverworks
- May 8, 2024
- 1
I have a yardman rider which starts fine and drives fine but the instance the blades are engaged the motor shuts off. any thoughts? thanks.
Uh, I did that the other day on my Country Clipper.
Parking brake was set. I don't know why the engine cut out when I engaged the blade PTO just because the parking brake was set, but it did. Guessing it is a deliberate design decision.
I could start it just fine with butt in seat and PTO off with parking brake set. Agree, I think there is an interlock. Don't think there is a mechanical connection, but it sounded like the blades were wedged when I tried to start them.When you set the Parking brake you can get off the machine but if the PTO is on it kills the machine so you wont get hurt. You can also start must machines when your off of it when the parking brake is set but the PTO must be off.
I am assuming that your Yardsman is a tractor style mowerI have a yardman rider which starts fine and drives fine but the instance the blades are engaged the motor shuts off. any thoughts? thanks.
Check for obstructions between blade and deck.I have a yardman rider which starts fine and drives fine but the instance the blades are engaged the motor shuts off. any thoughts? thanks.
