Scag freedom z starting problem
cnfixwd
I have an older freedom z. I start it. It runs for a few seconds and dies. I thought the PTO switch was bad I replaced it. It almost sounds like running on 1 cylinder. If I use starting fluid it will continue to run. Where do I go?
