Scag freedom z starting problem
cnfixwd
I have an older freedom z. I start it. It runs for a few seconds and dies. I thought the PTO switch was bad I replaced it. It almost sounds like running on 1 cylinder. If I use starting fluid it will continue to run. Where do I go?
What model and brand of engine do you have on the Scag.
Its a two cylinder extended life
That does not help.
We need the equipment model from its serial number tag and the model and spec (type) number from the engine. As you see below there is not just one machine or engine involved.
