rdavis0627
- Dec 14, 2023
- Threads
- 3
- 16
Hey StarTech, I put 5w 30 synthetic oil in it off something I found about a recommendation from B & S, how bad is what I've done?Do not be too concerned about it showing a oil filter.
That same model number engine used two different sumps, one with a oil filter and one without. The oil filter type is mostly for show to make you really got something better.
Usually just use straight 30w oil. Be extra careful when tightening the taper threaded oil drain plug, you can easily crack the aluminum sump at the thread boss if you strong wrist it. The sump is little wimpy weak in that area.
Best to use about 3 layers of teflon tape on the 3/8 pipe plug and just get it snug. I sometimes install a 6 inch length of 3/8 pipe nipple and use a cap on the end of the nipple so as the oil will drain outside of the frame into a catch pan.
The valve cover is the only good info for your engine. Most likely has the correct info and is the right cover.
You got lucky that the camshaft compression release was good.
