LawnWizard
- Nov 17, 2021
- 106
Hello all,
I'm working on an old (2009) Bad Boy Pro 27 with a Kohler 27 hp. I did a longblock swap using a used longblock and the original accessories including charging system etc. Mower preformed perfectly for several hours then began blowing the main fuse. I traced the issue back to the regulator/ rectifier. Swapped that out, go to go.....for about 45 minutes. Back to blowing the main fuse again. Obviously the regulator was bad but seems to be a symptom rather than the problem. Can any of the electeical gurus out there help me sort this please? Other than a bad stator or shorted wire, what would fry the reg?
Thanks!
Thanks!
