NobleFarmer
I'm not able to find a manual or parts spec online that shows where the oil filter is on this engine 21R707-0143-F1, if there is any.
Official site doesn't find any manuals for my model even though the store sells the engine model, other sites only have some diagrams but I couldn't find one regarding the oil filter, and this forum only had a few posts about 21R707 which didn't cover this topic or have a manual link.
The prior owner left a part (491056) that I thought was meant for Briggs & Stratton engines, so I thought I'd try to install that. I took off the top housing and disconnected the gas can, and still can't find it.
Any suggestions? Housing bolt in back right was the worst because of how close it is to the frame, couldn't get a socket set behind it, had to use a manual wrench for most of it!
Anyways, I'm trying to replace the oil filter since it's been a full season since I took ownership of it, and it's blowing lots of white smoke even after an oil change (SAE 10W30, and some SAE 5W30, both full synthetic), and doesnt sound good or move well. Air filter is fairly new & clean with only 20 hours on it, and replaced the fuel pump & fuel filter 10 hours before that. I only put ethanol free gas in it.
Thanks in advance!
Thanks in advance!
