MowerMark
yes it can they put light flywheels Then the blades acts as a flywheel.
Sorry, don't understand. Please state your post a different way. Are you explaining how these two problems are related?
I'm not skilled enough to do this. Will find someone.Looks simply like the bolt fell out, and since (as others note), the blade assembly acts as a flywheel, it may be a cause of the no-start, or a symptom. In any case, it looks like you should be able to reattach it by replacing the one bolt, so it would seem that that would be a cheap and easy test.
If you decide to replace, and since you seem to keep your equipment a long time, don't forget to consider the finite life of batteries on electrics, and due to thier proprietary nature, the relatively short period of time durimg which replacement batts are available.
When the spark plug on a single cylinder motor fires and causes the motor to spin, they used to rely on a heavy flywheel (the fan shaped disk on top of the motor) to continue the momentum and keep the motor turning until the next spark fires. Since then they are now using lighter materials to make the flywheel that can no longer supply momentum, so it relies on the weight of the blades to do it. This motor should never be run without the blades attached. Your pictures seem to show that your center bolt broke holding the blades onto the shaft. All you need to do is remove the broken part and get a new bolt to install the blades back on. Then all should work.Sorry, don't understand. Please state your post a different way. Are you explaining how these two problems are related?
