Just use a Pro Multi Mix oil and don't worry mix ratios if the equipment running anything between 16:1 to 50:1. It contains stabilizers. Here I use to have multiple cans of fuel going bad due all the different mixes. Now I just have one container for all 2 cycle engines. A lot easier to use up and to keep it fresh.
As for the ethanol affecting rubber yes it does dries it out a little faster but even regular fuel does this. Even the fuel additives which is in all fuels will cause problems.
