JD D140 drive belt slipping?
unioncreek
I have a JD D140 mower that I put a new drive belt on last spring. As the mowing season was ending up for the fall it started to slip more often. I’m wondering if either the drive pulley on the engine or the driven pulley on the transmission are worn out. Is there a way to tell if that is the case or can the belt wear out in one season. I have about 175 hours on the machine.
Thanks,
Bob
SeniorCitizen
Feel with your finger for a ridge at belt depth . The drive pulley usually wears ( fails ) first from wear .
Use a strong flash night and look at the engine pulley if it is polished nice & shinny at the root then it is worn out.
Have a look at the belt , it should show wear on the sides but not on the narrow end of the V
The usual cause is the pivot hole on the clutch tension arm worn oval and the bush it runs against because despite the owners manual showing it needs to be lubed no one ever does
The plastic V-Idler pulley are known to wear out quickly as Bert indicated the bottom (root) of the pulley will be shiny when worn out. Same as effectively having too long on a v-belt on the mower as it will start slipping.
Tiger Small Engine
OEM belts last for years if everything is correct. To really check thoroughly, you need to release belt tension and check each pulley, also check to be sure it has good belt tension. Is this an OEM John Deere belt?
unioncreek
I pull the deck off this morning and here is what the drive pulley looks like. There are ridges in it also. The plastic idler pulley looks good.
unioncreek
Yes, I put a JD OEM belt on last year. After taking the drive pulley off I removed the transaxle. The driven pulley on the transaxle is also shined right to the bottom. I’m going to replace all the pulleys plus the idlers and belt.
Bob
bluesky
The belts on my 54 inch mower deck (on JD X540) are ten years old and worn out. Two weeks ago, I ordered from Amazon a new deck belt, drive belt and a tension pulley. The cost was half what the dealership wanted. These new parts were the same quality as the John Deere branded parts. My total cost was $81.19 delivered to my home instead of the $150 plus from John Deere and I drive 60 miles.
