If it came new with synthetic oil then the assumption is it was designed to run synthetic oilHave a 2021 ZT Elite with the Kohler engine. The oem motor oil is Kohler 10w30 semi synthetic/ blend. thinking about using full synthetic 10w30. any opinions out there regarding this?
Came with a blend / semi synthetic, I'm thinking a full synthetic may be better for the air cooled motor?????If it came new with synthetic oil then the assumption is it was designed to run synthetic oil
Down side is it still needs to be changed every season unless you put a stirrer in the sump when it is not in use so it becomes very expensive very quickly .
What I always say what goes in is no where near as important as how often it comes out .
It makes no difference other than the fact that engines designed to run on full synthetic often have tighter clearances & smaller oil galleries.Came with a blend / semi synthetic, I'm thinking a full synthetic may be better for the air cooled motor?????
