Tiger Small Engine
- Dec 7, 2022
- Threads
- 3
- 1,649
Kinda wish I had funds available to have extra equipment but I have try to buy what works all around here. And yes most times it takes longer to get things out then it take to resolve a problem.
It sorta like needing to crimp a battery cable. It takes time to get the crimper out and back up which is only needed for less a minute crimping operation.
So let’s say you actually have to extract a bolt, or you have a blade bolt, or any bolt for that matter, and it takes you roughly an hour to extract or remove vs a few seconds. Do you charge the customer an hour’s worth of labor, or eat it? I have battery, electric, and air impacts. I know how to remove and extract bolts. I am aware of bowtie and star blades. Work on a lot of commercial equipment as well that doesn’t use star pattern.
Thanks in advance for you input.
