- Feb 19, 2020
- Threads
- 114
- 12,327
Yes there two basic type and several different mounting configs.
I have seen call three post and four post. These posts are also poles on schematics. It two large posts that the hi battery amperage to starter. Now the so-call has 12v trigger post with the frame of the solenoid providing the return ground. On the so-called four post the solenoid trigger coil is ungrounded (floating ground) and many mower use this as an additional part of the safety system.
