2012 GTX 2000 cub cadet rear
craigr007
when i go forward. the trans. grinds and will not go very well. but is fine going in reverse any ideas what it could be
Probably the forward pump motor but since CC and MTD is hiding the Hydro Gear model number in the IPLs try looking on the transaxle axle housing for the Hydro Gear model and serial numbers.
looks like a
918-3243 which translates to the BDU-10L-225 in hydrogear​
Strange I can't even get the Hydro Gear dealer portal to pull up the BDU-10L-225 pump on the search mode but did manage to it otherwise on the portal. The IPL only shows the pump section even though the BDU-10L series is listed as a transaxle/transmission.
Any way I added the CC-918-3243 to my inventory as the MTD price file has NLA it. I also added the BDU-10/21 repair manual to my database.
View attachment 67734View attachment 67735
Doesn't look like the search function is working with any model number
@StarTech Looks like the transmission is part number 918-04176 supercede to 759-04322
Kinda looks like we might start getting the CC parts through Gardner now that they installed a new system. Expensive as usual.
Either way neither of those number were in the last price update before change the system. Now I can't even get new price files until someone at Gardner gets things straigthen out but my confidence level is very low. It took over a month just to get to where I can login.
