Hey All...thanks in advance.
I'm stubborn.
I have a 2013 Troy Built riding mower with a 17.5 B+S engine. I have the standard problem with bending the intake (aluminum) pushrod, which I am certain is relate to overheating (happens less or can be avoided if I cut the 3 acres in sections). I keep a supply of them on hand and think I could probably change them blindfolded now.
I have this ritual when I start the mower now... I remove the spark plug and hand crank the engine a few times before starting it using a socket and a breaker bar, and I have noticed that there is often an odd resistance and a sound on the first crank...almost like the valve spring (I assume intake) refuses to compress and then does (or releases without the rod making contact).
Before I replace the cylinder head* I am hoping that some wise soul can confirm my theory that this will help and suggest any other options/repairs.
Like I said, I am stubborn, and prefer to keep things running rather than replace...I just replaced the inner tubes on my 42 year old snow blower (starts on one pull)
Thanks!
* I had to drill out and re-tap one of the exhaust bolt holes previously, so I am leaning away from a valve replacement.
			I'm stubborn.
Thanks!
