CV15S cylinder damage
I have a customer who has a 20 year old John Deere SST15 with a Kohler CV15S engine. He ran it without oil and, well, you know what happened. I'm trying to put a new crankshaft and connecting rod in it. However, when the connecting rod failed, it impacted the bottom of the cylinder and broke a chunk out. There appears to be wear marks in the cylinder. I don't think the piston travels down to where the damage is. Can I get this engine running or is the crankcase unusable?
Fish
I wouldn't bother with it myself. If it doesn't last very long, it will be a lot of money wasted, and your name will be associated with it.
that will be fine
get a die grinder or similar and make the hole smooth left right & top bottom so the edges do not break away
Thank you for the replies.
Bertsmobile1, have you repaired an engine with this kind of damage before?
VegetiveSteam
I agree with Bert that it will be fine. I would let the customer know what you found and let them make the choice on how to proceed.
Ok, I have one more question. Do you think I should replace the piston rings since I have to remove the piston anyway?
With that lick I would be careful inspecting the crankcase for damage too. Usually here I find it at least cracked.
Ok. I'll give it another look.
