1998 17 hp died wont start spins easy
engine turns over ,has zero compression,rods pistons crank all solid ,hows the cam driven in this 98 17 hp opposed flat head briggs and stratton?
Pull the heads the valve seats have come out holding the valves open. Most likely the exhaust valve seats, but could be intake. this is a common problem on the opposed twin briggs. If the seats haven't worn the block too much they can be put back in and peened back into place to hold them. i suspect that one had come out some time ago and was running on one cylinder and then it died after the seat came out of the other cylinder, so the first seat may have hammered the block pretty good and may not be easily repaired.
thank you ill look into it
I would check the "shear key" or woodruff key if you will.The flywheel can be spinning free without turning the engine at all.This would be where I would start.
