dougand3
- Mar 10, 2012
- Threads
- 13
- 461
Look at camshaft 46 in IPL. 2 teardrop lobes push rods for valves. The cam gear mates with crank gear. Cam gear could have jumped time. Also, 43 Oil slinger/gov can blow up. Can't tell from IPL but cams can have a boomerang compression release - spring loaded and clears away at run RPMs. It can blow up.
