l008com
- May 25, 2015
- 40
- 238
Neighbor gave me a 10 year old Craftsman Yard Vac that was "used once then I never used it again".
We have tons of large, old oak trees in this neighborhood that drop leaves the size of dinner plates, so a mulching yard vac is a very handy machine to have. Which is why I already have one! But mine is from 1994 and this one is close to 20 years newer.
He also stored it outside so after giving it a good external cleaning, I checked the oil level, put some gas in and started it up. After some initial sputtering (in the video) it started running great.The sputtering does not surprise me, theres no primer on this engine!
So I warmed it up for a minute, then killed it and changed the old oil with some super fresh stuff. I started it up again and it seemed to be running perfect. I brought it up to my driveway and did a bunch of passes and was really impressed with the performance. This machine sucks up leaves much better than my older one. If I can fix this one, I'll definitely use it every fall.
Here is where things went wrong. I sucked up leaves for 5 or 10 minutes. Towards the end, it felt like it was misfiring. It would run perfectly for a few seconds, then cut out for half a second, then come back. But the gaps between sputters were getting shorter, and the length of the sputters was getting longer, until the thing died. My first thought was, well the carb is probably dirty, if I keep running it with seafoam, eventually everything will clean out and be A-OK.
After doing some other unrelated things, I went back to this machine and tried to start it up. Nothing. At all. Not even a hint of firing. But more than that, the motor was spinning much faster, much more freely. It's like there was no compression at all. You pull the cord and the engine spins and spin. Now there is at least some compression, because when I pull the plug, plenty of air comes out. But I have no frame of reference so I have no idea if the air coming out is the normal, proper amount, or way less than should be coming out.
I am by no means an engine pro. But based on what I know about engines, my first thought is that it kinda feels like one of the valves got stuck open? So theres no compression and thus no firing. And that could potentially explain how much more freely the engine spins? Beyond that, I am at a loss.
I have a short video linked below.
Part 1 is me pulling the cord early on. I was trying to start it and I forgot this machine require the bag in place to start. But compression felt normal
Part 2 is when I finally started it for the first time. It sputtered a lot but never died. And once it kicked in normally, it ran great. Perfectly I'd say. And it kept running perfectly the whole 10 or 15 minutes I was using it, until the very end. The timeline is that part 2 happened, then i changed the oil, then I started it back up and used it.
Part 3 is after it died and I couldn't get it running again. I pulled the cord and the engine spins and spins way too easily. Once in a while you'll hear and feel one or to pumps of compression but then its quickly back to nothing again.
So what do you think? The odd behavior feels like it probably points directly to what the problem is, but I don't have enough small engine experience to know what that actually is!
