Hobbesnmina2001
 - Nov 24, 2023
- Threads
 - 1
 - 7
Hi all, new member trying to help a friend. I’m not a small engine expert but worked on cars.
My friend’s John Deere Series 100 125 Automatic with 20 HP Briggs V Twin has a replacement engine with some use. The engine quit and seems out timing. After watching YouTube videos I’ve checked the valve adjustment, fuel delivery and has spark. Engine had a starter and flywheel ring gear replaced. It’s not the fuel solenoid.
The engine was pulled and this model doesn’t have a decompression lever, cam looks okay and timing marks line up.
With spark plugs out and ground to head both have spark. I haven’t pulled the flywheel yet but trying to eliminate any other possibility before pulling it.
Flywheel doesn’t feel loose, owner did hear a loud sound when it quit. I never heard it yet, engine spins fine then every once in a while a backfire. The valves and push rods all go in and out don’t seem bent.
Besides a sheared flywheel key any possibilities? A small engine repair guy doesn’t think it’s the flywheel key. Saw the engine and felt it turn with crank case cover off. Nothing seems damaged inside and saw the camshaft lined up and cam condition and timing.
Cylinder compression was at 140 lbs for #1 (left side facing forward) and 160 for #2 (right side. I thought it was good amount although 20 lbs difference a bit concerning.
Any diagnosing thoughts and ideas would be great. My friend doesn’t have a lot of money and we’re trying to help although small engines admittedly are not my forte.
I don’t mind pulling the flywheel to check for a sheared key but wondering if there’s anything else it could be or to check?
Thanks
Thanks
