- Feb 19, 2020
- Threads
- 118
- 12,651
Well one customer here has over 4000 hrs on a Kawasaki FX850 engine and it is still running strong. The only thing than a complete carburetor including throttle bushings that has done to the engine is an oil Gerotor replacement. This seems to a common problem the carburetor where the throttle and choke shafts wear in two. The last it took a sch 80 brass pipe to make the bushings.
And doing a compression test on the the FX751 is basically useless due ACR. The engine passes the modified leak down test fine with < 20% loss which surprises me consider the #2 cylinder problems. If the customer keep running it would had gotten to be a cold cylinder problem but currently it is just a hot cylinder problem. I do have the needed parts on order but the distributor has them on back order.
I kinda lucky to have ran into this just a month ago on another Kawasaki FX-T00V with over 3000 hrs on it too except it had already gotten to the cold stage failure. Slightly different resulting damage so he got lucky on the repair bill. Now of his previous repair shop told him last year he need a $4000 plus engine, which I repaired for $300 last summer due high oil usage. That #1 cylinder but this #2 cylinder went down. Same root cause but did some other damages.
With Kawasaki engines I am seeing several with over 3000 hrs still running strong but of course the customer are doing regular oil changes and using good oil.
