Here is one for you guys to figure out.
Kawasaki FX751-AS04
After operating for 30+ minutes, the engine will after fire on shut downs and will back fire thru the air cleaner on start ups. Luckily I already repair one that was backfiring out the air cleaner a month ago so I had inking of where to look for the problem. Problem was confirmed so the parts are on order; although, the distributor said they are on back order for nearly a month.
It is bad as I had already had to replace the starter due a hot restart problem. The starter flat refuse to operate when it was hot. Not good when the client uses the mower commercially. And it also took me nearly 5 weeks to get to mower due to severe backlog due health issues here.
Kawasaki FX751-AS04
