ThatOneGuy1968
So my part number would be?? 796335??
Is that a Briggs number or ?
So I’m told to put nylon rope in my cylinder on tech to torque flywheel bolt..So my part number would be?? 796335??
Yep, put nylon rope in the spark plug hole and you will be fine. I do it all the time.So I’m told to put nylon rope in my cylinder on tech to torque flywheel bolt..
I am not gonna do that and break my piston at the wrist pin.. I don’t have a special tool for this.. any ideas??
That works as you being using the engine's PTO pulley or you can just use a large flat blade stuck in the flywheel ring teeth and held up against the ignition coil mounting stud. If I can torque 48M series flywheel to 140 ft/lbs using ignition coil stud then torquing the 31 series to 110 should be fine which I have also done here. Just make the ignition coil is mounted it stabilizes that stud.The other alternative is to hold the other end of the crank
Easy to do if the blade is there
