I did notice a slight twist in the front axle, I think you may be on to it the more I’ve thought about it.ThanksAnd in particular the front cross member and it's pivot bolt .
Older cubs had a grease nipple for it as dose most JD's
Ne cubs do not they just use a softer bolt
Plus the wheel bushes + the king pin bushes
I hope to have time this weekend to check it out, the diagrams on the cub cadet sight don’t show bushings or grease fittings, so just hoping for something I can fix. Otherwise it may become a parts machine for the lt 1050Some have adjustments , some you jus change out the pivot bolt, good ones have a replaceable bush, usually high density nylon
I some times cut washers from old HDPE drums to take up the slop
