Although the YTH 180 IPL don't show it there is supposed to be a belt retainer on the transaxle per Hydro Gear IPL lookup.
These are HG 51229 bracket and 50653 (10-32x1/2 self tapping screw).
Normally in order to the drive belt the fan must be taken off and the driven pulley slide up so the belt can be put on. IF you are to get the belt on without doing this either bracket is missing or severely belt out position.
