Need some help on this. Background story on this, I changed out the ignition switch several weeks ago with a cheap one from Amazon. Everything was fine for two yard cuttings. Next time I tried to start it, nothing. I didn’t even think about it being a fuse, bought another switch from local shop. Then it dawned on me about the fuse, sure enough it was blown. So I put a new 20A in and rock n roll. Finished cutting, turned it off, tried to start again and fuse is blown again.
So….I put the new switch in and another fuse and back in business again….but I’m skeptical.
Can a bad ignition switch cause this??
Any ideas and suggestions would be appreciated.
