Guess what engine this is.
Scrubcadet10
Moderator
Staff member
Owner kept having to add oil. Cover gasket was leaking and the yellow EZ drain wad leaking bad.
mcostello
Well, it's not a Lawn Boy.
I think it is a Morse Fairbanks hit N miss left out it the barn.
Be careful it is a werewolf engine...
I beginning to think it take courage to own a Kawasaki FX00V engine. Less than 500 hrs done blew #1 cylinder head gasket. Choke vane done wore a groove in the carburetor cause the choke shaft to hang and get bent. And now #2 exhaust valve sticking causing the push rod to dislodge at start ups. Customer owes a Fx850 with 4000 hrs and the only thing I done so far other routine mainaitance was to replace the oil pump at 3500 hrs.
MParr
Kohler Courage 20hp.
