PTmowerMech
ZT42. 915178
The deck bearings where howling so after replacing them with new, after tightening them up, they still howl. Especially one, that has resistance when I turn the blade. Remove the spindle, and rotate the bearings with your finger, and they're quiet as a mouse. Nice and smooth.
These are the spindles that has no nut on top. One nut, with two holes that pull the bearings together, with a spacer and hold them in place. (countersinks into the bottom of the spindle) Then has the blade nut.
Bearings are square in their place. Spacers are all in.
I replaced these spindles 4 years ago, almost to the date, with OEM.
Also, I'm thinking about removing the inside seals on these bearings, since I can't remember where I got them, and installing grease zerks. What's a good grease to use?
Thanks in advance.
Thanks in advance.
