husqvarna 22yth42 turns off
451johnny
my Husqvarna tractor starts than turns off after 10 minutes ? I got it cheap ( now I know why ) it didn't have an air filter not sure if that has something to do with it ? and I can't see the condition of the gas filter because it's a non see thu filter.. and sometime it turns off as soon as she starts.. any help will be greatly appreciated it johnny
Put a new air cleaner Asap, may as well change the fuel filter too, then start over- if it starts up again after stopping it's most likely a fuel supply issue.
remove the blower housing and remove the kill wires from the magneto coils
IF problem goes away you have a wiring problem
If it makes no difference then it is an engine problem or fuel problem
ok i'll be checking t
ok i'll be looking into that today thanks ....johnny
