PTmowerMech
- Apr 16, 2018
- Threads
- 443
- 3,421
Does this engine have a compression release? I'm seeing some with, and some without. The engine is acting like, if it's got an ARC, the valves need to be adjusted. But it's got one valve cover bolt that I'm almost sure is going to break off in the head if I mess with it anymore.
Build date 06/30/2015
Serial number 4518109303
If not then it's gotta be a weak starter or battery, right?
