Cub Cadet XT1 LT46 with Kohler 7000 series engine.  I was fouling plugs really quickly and the engine was stuttering badly. I tried new plugs with no relief. While running, I tried removing the air filter which looked pristine and the mower ran perfectly.   It is a mower I got as "non-running AS IS" from Tractor supply at a large discount.  I took the carburetor solenoid out and snipped the plunger off and installed an in-line fuel shutoff valve. The hour meter showed 6 hours so it seems unlikely the air filter would be obstructed from normal use.  Maybe then original owner sprayed something in it but it seems to be clean. I will get a new air cleaner but if that doesn't solve things, what could cause the rich condition?  It has a manual choke and the butterfly closes when the lever is in then choke position and is open when the lever is in other positions. Confirmed good gas that burns well in my other mower.  The fouled plugs are sooty.
