tgzzzz
 - Aug 11, 2012
- Threads
 - 9
 - 85
This is hard for me ... but I'm doing it.1.Max revs all the time. Provides max cooling and max oil lubrication. Never idle down.
Really easy, just leave the throttle alone.This is hard for me ... but I'm doing it.
what air pressure setting are your tires at? If set at max tire recommendation, let 3 - 4 #'s out of each and see if that smooths things out for you. Don't go too low though or you could easily pop a tire of its rim . . . . .Key arrived today. Put gas in it. It started right up. Took it for a spin in the yard (little less than an acre) - bounced around a bit. Works well. Have identified air filters and oil filters. Bagger should be available Thursday.
Thanks - I'll check.what air pressure setting are your tires at? If set at max tire recommendation, let 3 - 4 #'s out of each and see if that smooths things out for you. Don't go too low though or you could easily pop a tire of its rim . . . . .
