New Owner
Charlie8d
If you are going to use the vacuum often, cut the grass more often & don't let it get too high, or cut too much off at a time. Never cut when wet. Run RPMS at full speed & drive a little slower. Clean inside of the chute & tube after each use. KEEP oil checked. Many of these have a Chinese built engine , no matter what the decal says , so take care of it, & if anything starts to go wrong, use the warranty.
Honest Abe
Key arrived today. Put gas in it. It started right up. Took it for a spin in the yard (little less than an acre) - bounced around a bit. Works well. Have identified air filters and oil filters. Bagger should be available Thursday.
what air pressure setting are your tires at? If set at max tire recommendation, let 3 - 4 #'s out of each and see if that smooths things out for you. Don't go too low though or you could easily pop a tire of its rim . . . . .
Manfred
Thanks - I'll check.
