mrmupton
Hi, My Hustler Fastrak SuperZ 52” with a Kawasaki engine (1000 hours) is burning oil after a hard days work. It got real bad when i was cutting some thick grass and I saw grass covered the air cooling fan so it was definitely starting to over-heat. It only smokes when hot toward the end of my 5 acre lot generally, and not usually a whole lot. Smoke is not coming from exhaust but from under engine on mounting plate.
I’m planning on changing out the oil and cleaning under engine to see if there is an oil leak, but wonder if there is something else it might be. It seemed better immediately after cleaning out underneath the engine and the air cooling fan. What can I rule out as an issue? I don’t think its a piston ring as the exhaust is clear.. could be a leak or a gasket? I’m wondering if it is the later because its only an issue under duress.
Would love your thoughts and recommendations! Thanks!
