OK that makes a difference.Now that looks helpful for my 81 yr old body! [My mind is still 16.] Thank you! I have one on order.
get a full body harness , not just the shoulder strap they usually supply
When you mount your trimmer to it loosen the mount on the trimmer and move it to a position that when you are standing strait up, not hunched over the trimmer head is about 2" off the ground without you touching it then tighten the mount
This way all your arms are doing is positioning the trimmer head left right.
The better ones will have a mounting clap that allows you to rotate the machine side ways for edge triming
The cheaper one just have a hook
