PTmowerMech
- Apr 16, 2018
- Threads
- 440
- 3,389
Thinking about the fuel & air flow system, since the timing and everything related has been covered, Maybe something jarred the carb or broke something on the intake. Nothing I can think of along those lines seems plausible.
I'm guessing the coil wasn't damaged or moved, since it doesn't touch the flywheel.
Short of the flywheel key being damaged, I can't see anything in or on the engine changing enough to not fire and run (even roughly).
My final answer (without phoning a friend) is something came loose in the carburetor.
