This is the Ruixing carb used on engines built after 2016 with a fuel pump.
				Parts lookup and repair parts diagrams for outdoor equipment like Toro mowers, Cub Cadet tractors, Husqvarna chainsaws, Echo trimmers, Briggs engines, etc.
					www.partstree.com
This is the Nikki carb used on engines built before 2016 for gravity feed engines.
					www.partstree.com
i know that is says the Nikki carb supersedes to the Ruixing carb, but my experience has shown me that they don’t often work like the engineers say they will.  Pressure on the float needle is different, higher with a fuel pump, lower with gravity feed.  Sounds like this may be your problem, but make sure you read my signature.
