Jtich85
- Jul 17, 2023
- 6
Okay stay with me on this one because I am a little rusty on my small engine repairs.
two months ago I was given a 2005 24V48 Husqvarna riding mower. It was not running and had not been started for two years. What could possible go wrong.
week one - After replacing the battery and started solenoid, new spark plugs, and draining the gas I got it started. I did however in the process of playing with everything break the fuel tank grommet that secures the fuel line in place. I didn’t know enough to figure out how to get a new one to fit in that tiny hole and I was trying to put it on the hose first. So the end result was using some glue to hold it mind place while I mowed.
Week two - lawn mower turned but would not start. I drained the fuel again, added a new fuel filter, and it fired right up. The grommet had come lose so I glued it back…
week three - lawn mower turned but wouldn’t start. Drained the gas and cleaned the carburetor. It fired right up. The grommet had come lose so I glued it back…
week four & five - lots of rain and not a lot of mowing
week six - the lawn mower wouldn’t start. Drained the gas and refilled with ethanol free gas. No start. Took the carburetor apart again and cleaned it. No start. Noticed the grommet had come completely out and there was junk in the fuel filter. I removed the gas tank and cleaned it rinsing with fresh gas.
When I was removing it I noticed that the vent line going from the gas tank to the intake manifold was broken and had been broken for a long time. I reconnected it and FINALLY figured out how to correctly install the grommet. I imagine a ton of water and junk got into the tank and fuel system by now.
I cleaned the fuel filter and filled the tank up with gas. When I went to turn the key I closely watched the fuel filter and it filled with more junk. I installed another new fuel filter. This time when I went to start it no gas pumped into the fuel filter. Not a drop.
I replaced the fuel pump and fuel lines and still no gas moving into the filter.
Next I noticed it was no longer clicking when I turned the key so I replaced the fuel solenoid and carburetor (didn’t fill like waiting for the solenoid to arrive). Turned the key - no gas going to pump
At this point I noticed that the mower wasn’t really making the same crank noise. It sounded like you would expect if there was no gas going to the spark plugs. As I continued to trouble shoot it over the next few days that noise got tighter and slower until eventually it just stopped. Now when I turn the key all
I get is a rapid clicking noise. I am getting the new battery tested tomorrow but I am honestly lost at this point.
Absolutely ANY help would be greatly appreciated.
