So you watched the rocker arm travel?Thanks for the replies. It has a carb off a running mower. The valves are opening and closing as they should and the decompression is working.
If i ket it sit for a couple days it will run perfect for a few minutes then it acts like i turned the key off. No sputtering. Im stumpedOK Zav we will do it this way.
Get a can of carb cleaner and start the engine
As soon as it starts give the carb short shots of carb cleaner ( air filter removed ) and keep on doing this for for a minute or more ( it will run rough & sound aweful ).
If you can do this then you have a fuel problem
If you can not do this then you have an electrical problem
Let us know what the results are .
That is not what you were asked to doIf i ket it sit for a couple days it will run perfect for a few minutes then it acts like i turned the key off. No sputtering. Im stumped
