JRD1054Cub
- Apr 11, 2021
- 20
2009 SLTX1054 Kohler 735S 26HP twin.
Run into a problem that has me stumped.
Engine will turn over but won’t start.
I have cleared the fuel lines. Replaced fuel and oil level is good.
Replaced fuel pump and filter is fine.
Air filter is clean.
But I still think it’s a fuel issue because it will run briefly with a shot of starter fluid, then cut out.
Spark plugs are new. I replaced the carburetor last season. The odd thing is, it was running ok about 3 weeks ago and this week it decided it was done.
I will say that when it was running, it would backfire every so often while blades were engaged.
Any suggestions?
Any suggestions?
