Snapper/Briggs and Stratton issue
TeeTime71
Snapper P2187520 8.75 ft/lbs 190cc Professional Series with a Briggs and Stratton 12S902-0126-B1 and it heavily smokes on startup, more than normal. 15+ years old. Self-propel also quit working but that is a separate issue. On small engines such as this, what entails a "rebuild"? Carb kit?
Well if you don't already have the necessary tools it would cost more than a new to rebuild. Most shop now don't even rebuild these engines. Current direct replacement was 121S02-2025-F1 which is around $300 plus shipping but it is NLA. But the 190CC promo 125P02-0012-F1 (around $320 + shipping) is available.
TeeTime71
Spoke to an out of state shop today (will be there next week and had my fingers crossed) and was told Snapper is out of the walk behind mower business. Local shop had no information. Murray purchased the name 10 years ago "and is not same company". I love the Hi-vac design.
TeeTime71
What is the difference between the two engines? NLA I understand, just curious.
The main is the promo does not have an alternator or electric start capabilities.
Engine Overview​
Information​
Model Number 121S02-2025-F1
Engine SeriesPROFESSIONAL
Replacement Engine​
Replacement Engine:121S02-2025
Crankshaft 796468
PTO Shaft Diameter0.984
PTO Shaft Length3.156
Woodruff Keys2x #605
PTO Threads0.375-24 UNF
Replacement Shortblock:798773
View Replacement Details
Engine Specifications​
Model Number121S02-2025-F1
Engine FuelGasoline
ConfigurationVertical
CylindersOne
SKU121S02-2025-F1
Gross Horsepower*875.00
Air CleanerAIR CLEANER, DUAL ELEMENT OVAL
Air Cleaner CoverAIR CLNR COVER, 290 SATIN BLAC
BearingsBEARINGS, PLAIN PTO
Blower HousingREWIND COVER, LS, 290 SATIN BLACK
Bore TypeKoolbore
Bore Size2.688
Stroke2.040
Casing ClampsCASING CLAMP & SCREW, LOOSE
Controls GroupsCONTROL GROUP 82, MODEL
Cylinder HeadCYLINDER, ALUMINUM
DipsticksDIPSTICK, OPPOSITE CA
Oil DrainOIL FILL, OPPOSITE
FlywheelFLYWHEEL, LIGHT NON-ELEC START & NON-ALT
Fuel SystemFUEL TANK, CIC, FUEL FRE
ExhaustMUFFLER, PERFORMANCE W/TUB
Spark PlugSPARK PLUG, RESISTOR
Starting SystemSTARTER, REWIND POSITION - 5:30 O'CLOCK
Technical Specifications​
Model Series121S
Power Lbs/Ft of Torque8.75
Engine Series875
Displacement190
Oil Capacity20 oz (0.6 l)
Valve ConfigurationOHV
Flywheel Torque60 lb/ft (81.5 Nm)
Governor Arm Torque40 lb/in (4.5 Nm)
Carb Mount40 lb/in (4.5 Nm)
Plug Gap0.02 in (0.50 mm)
Intake Valve.003-.005 in (.08-.13 mm)
Exhaust Valve.005-.007 in (.13-.18 mm)
Idle Speed1750
Air Gap.010-.014 in (.25-.36 mm)
Flywheel Puller Part19619
Flywheel Holder Part19433
Connecting Rod Torque100 lb/in (11.5 Nm)
Sump Torque100 lb/in (11.5 Nm)
Head Torque220 lb/in (25.0 Nm)
Alternator Specifications​
Alternator794103
TypeDC Only
Testing RPM2800
DC Amps0.5 adc
Engine Overview​
Information​
Model Number125P02-0012-F1
SKU125P02-0012-F1
Model/Type/Trim125P02-0012-F1
Air CleanerDual Element
AlternatorWithout
CarburetorReadyStart - Full System
Casing ClampWithout
ControlsFixed Speed
CrankshaftStraight - 25MM 3.156" PTO
Crankshaft Details1/4" Keyway, 3/8-24 UNF-2B
Emissions CertificationEVAP/EXH/EU
Engine BaseStandard (Non Flange Mount)
Engine PackageHigh Debris
Engine Sold InB&S Eng Replacement - USA/CAN
Engine Speed3100 +/- 0100 RPM - No Load
FlywheelLight - Aluminum
Fuel CapBlack 1/4 Turn
Fuel ShutoffWithout
Fuel TankEVAP - 1.0L
Label Power875 Professional Series,8.75TQ
Muffler GuardStamped
Oil DipstickExtended - Black Cap
Oil DrainPlug
Oil FilterWithout
PTO BearingPlain
Rewind Position5:30
Model Series125P
Engine Series875
Displacement190
Oil Capacity20 oz (0.59)
Flywheel Torque60 lb/ft (81.3 Nm)
Governor Arm Torque30 lb/in (3.4 Nm)
Carb Mount60 lb-in (6.8 Nm)
Intake Valve.004-.008 in (.10-.20 mm)
Exhaust Valve.004-.008 in (.10-.20 mm)
Idle Speed1750
Connecting Rod Torque97.5 lb/in (11.0 Nm)
Sump Torque110 lb/in (12.4 Nm)
Head Torque210 lb/in (23.7 Nm)
Top No Load (rpms)3100
sgkent
As an alternative watch FB marketplace and CL for a similar mower that has a lower hour engine but needs maint, then use that engine.
