2013 Badboy elite
mike coulter
I am having an issue with the left brake not releasing. I’ve sprayed the cable. Sometimes it’ll release then some time it doesn’t.
another issue I’m having is the spring for the drive belt tensioner broke and I can’t find one. Need a part number. Even looked on bad boys website and can’t find it
Any help would be greatly appreciated 🇺🇸🇺🇸
The drive idler spring is PN 034-2009-00. It is locate on Actuator IPL page.
Bad Boy 034-2009-00 Spring - eBay
Also you may need a section 1/2-13 all thread with a hole drilled through one end and a couple 1/2-13 hex nuts. Bad Boy wants nearly $13 for this item. Lowes has a one foot for around $3.
mike coulter
Appreciate the feedback Startech
I just ordered the spring
You know anything about the brakes?
It’s not the brake cable because it engages fine. It’s just that when the brakes are released, sometimes the left will stick
Does that brake plate have its pull off spring? Item #22 It goes between items #10 and #20.
Also the cross over brake bracket #10 could be bent a little.
mike coulter
Appreciate the information
I’ll have to look and see when I get back home
I’m not seeing item #22 though I see the 10 & 20
