hollydolly
- Sep 10, 2018
- 61
Bought new in 2010 Zero turn, Z425-54c
Has always cut great, until now. All the sudden blades are slow to engage, cutting grass above 3 inches blades rpm slows down while motor rpm stays the same. I have cut 24-inch Johnson grass in the past with no problems.
In 13 years, this has never happened before. Mower has been very well taken care of.
I don't think belt is slipping as it does not squeak and no smell of belt burning.
Could it be the PTO clutch, if so, how do I check it?
Thank you for any help.
