BillCreighton
 - Jun 23, 2023
- Threads
 - 1
 - 3
I have a 2019 Cub Cadet LT50 with a Kohler KT735-3076 engine with about 220 hours. After cutting a field for about an hour, the engine started choking and acting like it was starving for fuel. Pushing the choke forward solved the issue for about a minute, and the problem returned. I have only ever used ethanol-free gas.
I have followed the troubleshooting manual without success. Thus far:
Replaced spark plugs, fuel filter, and air filter.
Cleaned fuel lines into the tank and throughout
Rebuilt the carb (OEM kit)
Changed the fuel pump (OEM)
Tried an aftermarket carb (ruling out the solenoid)
Used fresh ethanol-free gas at each change from a fresh can.
Next up - fuel from a separate source and then ignition packs.
Any other suggestions would be very much appreciated.
Thanks!
Thanks!
