I have a Scag STT61-25ch mower with a replaced Kawasaki motor. The serial number on the chassis indicates that the original motor was a Kohler. The new used Kawasaki motor I installed starts fine with the key but will not shut off with the key. Therefor it has a wiring harness for the previous Kohler motor. There is an aftermarket switch on the side of the console box that might have been used in the past as a kill switch. Since I purchased the Scag with the blown Kawasaki engine and have no history on the machine, it’s hard to say what happened to the original kill switch. I have reviewed the wiring diagram for the mower to help identify which wire is responsible for shutting off the engine when I turn off the key, to no avail.
Does anyone have any ideas which wire can kill the motor on a Kohler harness for a Kawasaki motor?
Thanks in advance.
Thanks in advance.
